Hello I'm new. I have downloaded k roset lite and want to try the sample projects to see how it works. he won't let me, he asks for a license.
K Roset lite
Moises -
January 12, 2021 at 6:22 PM -
KROSET Lite only requests license information on opening of the application and does not prevent you from opening sample projects.
However, due to limitations of 'Lite' version, some sample project functions will not function due to the limitations in place, but code execution is not restricted.
I forgot to mention, when you installed KROSET, the folder contains several help pdf documents in the root directory structure of the installation.
Attached is a document that refers to using the demo projects, however you will notice some do not perform exactly as described due to limitations of Lite version.
: pulgar arriba:
can you try a sample with only one robot ?
