I am using background program to turn all outputs off when an error occurs:
Code:
LBL[1]
IF UO[6: FAULT] = ON JUMP LBL[2]
JMP LBL[1]
LBL[2]
DO[101] = OFF
DO[102] = OFF
However, I get the error: INTP-202.
How can I fix this simple problem?
Code:
LBL[1]
JMP LBL[1]
LBL[2]
DO[101] = OFF
DO[102] = OFF
You cannot jump back in BG logic, only forward. Jump labels aren't necessary anyways. Also, use the If statement with parenthesis. BGlogic automatically loops.
Just use this:
If (UO[6]) Then
DO[101] = OFF
DO[102] = OFF
End If
Thank you HawkME .
When I go to Background Logic: MENU > SETUP > BG Logic, my Program: DEMO_BG got STATUS; Stop. I feel ike it never runs.
Can you explain why?
When I manually set RUN.
The following error occurs: Invalid Item for Mixed Logic..
I am on a fanuc robot LR 200iC/5L, software version 7.50
So I can use IF statement, but not IF THEN
Code:
Program name: DEMO_BG:
IF (UO[6: Fault]), CALL DEMO_IO_OFF
Program name: DEMO_IO_OFF:
DO[101] = OFF
DO[102] = OFF
why you dont use,
If (UO[6]),Do[101] = OFF
If(UO[6]),DO[102 = OFF
Yep, you cannot call programs in BGlogic. You can use the inline if statement or directly set values. that's about it. On newer controllers if/then/else/endif is available.
