Is there a way to create a macro program and run it in background logic to jog group 2 of the robot. So I have a cell with 2 Headstocks and I want to be able to jog the headstock that isn't running to make it easier to load parts. I know there is an option called detached jog but before I go down that road I wanted to get some input on here. Thanks
Jogging a group with a digital input
joshrice1 -
November 3, 2020 at 5:40 PM -
Hi joshrice1,
Background logic can't lock a motion group!
create one or more tp programs that will move the group to the needed position(s).
(Maybe with a Skip Condition inside for the DI)
Start these programs via Manual Function or DI...
check out if this is a "safe" solution!
best regards PnsStarter
You could set DI as RSR input. With button pressed you would run RSR program in which you would move axis by some angle.
I used this one where operator moved G2 by 15° with each button pressed.
Macro Job with Headstock Group Masked. Under MACRO menu, assign the DI's (Positive Jog and Negative Jog) you want to use to trigger the Macro. Here is an example of a job I wrote a while back:
/PROG JOG_A_SIDE Macro
1: IF DO[77:RefPos2 G3 SideB @ OP]=ON,JMP LBL[999] ;
2: LBL[1] ;
3: PR[100:Jog_Variable]=JPOS ;
4: IF DI[28:Jog A Positive]=OFF,JMP LBL[2] ;
5: ;
6: IF DI[7:A SIDE SHOT PIN EXTENDED]=OFF,JMP LBL[2] ;
7: ;
8: PR[100,1:Jog_Variable]=PR[100,1:Jog_Variable]+5 ;
9: ;
10: LBL[2] ;
11: ;
12: IF DI[29:Jog A Negative]=OFF,JMP LBL[3] ;
13: ;
14: PR[100,1:Jog_Variable]=PR[100,1:Jog_Variable]-5 ;
15: ;
16: LBL[3] ;
17: ;
18:J PR[100:Jog_Variable] 100% CNT100 ;
19: IF DI[28:Jog A Positive]=ON OR DI[29:Jog A Negative]=ON,JMP LBL[1] ;
20: ;
21: LBL[999] ;
Unless I'm misunderstanding your application - this should work for you, but of course change the increment/speed %'s if your application does not need the speed. With the IF, JMP LBL at the end, this should cause the macro to act like a BG_JOB, but not be a macro job.
