CAST_ functions buffer declaration
  • lmonari
  • October 12, 2020 at 9:30 AM
  • lmonari
    From my experience on KSS 8.3, the buffer array of the CAST_ functions must be locally declared.
    So, for example, this code will result in a compiler error:
    DEF ExampleError( notLocalBuffer :IN )
        DECL CHAR notLocaBuffer[]
        DECL INT offset, aInt
        offset = 0
        CAST_FROM( notLocalBuffer[], offset, aInt )
    END
    while, this will give no error
    DEF ExampleOk( notLocalBuffer :IN )
        DECL CHAR notLocaBuffer[], localBuffer[4]
        DECL BOOL res
        res = strCopy(localBuffer[], notLocalBuffer[])
        offset = 0
        CAST_FROM( localBuffer[], offset, aInt )
    END
    The same happens with CAST_TO.
    Nothing changes if the buffer is declared as a global variable or if the buffer is passed by reference ( :OUT ).
    Does anyone know why?
    Are there other ways to use the CAST_ functions with not locally defined arrays?
    Thank you for the help
  • dexterv
    15
    110
    • October 12, 2020 at 12:06 PM
    FYI there is a typo, you have notLocaBuffer[] and notLocalBuffer[]
  • SkyeFire
    1,044
    9,391
    • October 12, 2020 at 2:50 PM
    Quote from lmonari
    What compiler error, specifically? At which line? Details matter.
  • lmonari
    • October 12, 2020 at 3:42 PM
    Quote from dexterv
    Yes, sorry for the typo
    Quote from SkyeFire
    At the line with the CAST_ command, the error is "Array index exceeds array limits".
    I attach a screenshot with the code and the error as displayed on the pendant.
    Images
      • 104.46 kB
      • 651 × 578
      • 21
  • SkyeFire
    1,044
    9,391
    • October 12, 2020 at 4:08 PM
    DEF ExampleError( notLocalBuffer[] :IN )
  • panic mode
    1,268
    13,040
    • October 12, 2020 at 4:11 PM
    so how about those details...? how and where is everything declared and initialized?
  • lmonari
    • October 12, 2020 at 6:08 PM
    Quote from SkyeFire
    The brackets in the definition of the input array do not affect the problem. The same error persist even with the brackets. as you can see in the attacched image (left side).
    Quote from panic mode
    My goal is to have a procedure that takes in input a char array of variable lenght and perform a CAST_TO or a CAST_FROM using this array as buffer.
    The example i reported is defined in a file .src with the same name of the procedure, located in a subfolder of KRC:\R1.
    In this particular case the procedure I am showing in the snaps is named "test_cast" and is written in the file "test_cast.src", located in "KRC:\R1\test" folder.
    I also tryed to declare a function instead of a procedure, as shown in the image (right side), but the error persist.
    Thank you for your help
    Images
      • 308.26 kB
      • 1,663 × 779
      • 19
  • panic mode
    1,268
    13,040
    • October 12, 2020 at 6:40 PM
    you are still showing same thing (inside of your sub or function) where runtime variable is declared but ... not answering the question....
    you have not shown how and where external variables are declared and initialized... i am talking about variables PASSED TO your sub or function when your sub or function are called.
  • lmonari
    • October 12, 2020 at 7:14 PM
    [...] i am talking about variables PASSED TO your sub or function when your sub or function are called.
    Here I hope to give you a better example, also with external variable initialized.
    DEF test_module ( )
    DECL CHAR myBuffer[12]
    DECL INT myInt1, myInt2, myInt3
    DECL INT offset
    ; Initialize ints
    myInt1 = 10
    myInt2 = 20
    myInt3 = -30
    ; Cast to myBuffer
    offset = 0
    CAST_TO(myBuffer[], offset, myInt1, myInt2, myInt3) ; this works as the buffer array is defined locally
    ; Cast from buffer using a subprogram
    castFromInSubprogram(myBuffer[])
    END
    DEF castFromInSubprogram( aBuffer[]:IN )
    DECL CHAR aBuffer[]
    DECL INT aInt1, aInt2, aInt3
    DECL INT offset
    offset = 0
    CAST_FROM(aBuffer[],offset, aInt1, aInt2, aInt3) ; this does not work. Error: "Array index exceeds array limits"
    END
    All the code above is contained in one single module.
    The error persist if I move the declaration of the char array "myBuffer" in the .dat file of the module.
    Thank you again for your time
  • panic mode
    1,268
    13,040
    • October 12, 2020 at 8:10 PM
    i have tried it on KSS8.5.8 and can see the same behavior.
    passing array is done correctly and works for pretty much all other purposes but clearly CAST_FROM() cannot handle it.
    buffer array CAN be declared in a local DAT for example... but then there is no need to pass it as parameter, it can be used directly.
    problem seem to be only when passing buffer as a as parameter. perhaps has issue with dereferencing.
  • lmonari
    • October 13, 2020 at 9:45 AM
    • #11
    [...] but clearly CAST_FROM() cannot handle it.
    The same applies to CAST_TO().
    [...] problem seem to be only when passing buffer as a as parameter. [...]
    Yes. Not only, as you suggesteded, the problem can be avoided declaring the buffer in the local DAT file but also if you declare the buffer as a GLOBAL variable and then using it directly in any subprogram, still without passing it as a parameter.
    Thank you very much for the help
  • panic mode
    1,268
    13,040
    • October 13, 2020 at 1:47 PM
    • #12
    you are welcome
  • declaration
