Create new workcell error
  • Swicke
  • October 2, 2020 at 11:13 PM
  • Swicke
    Hey there,
    I've started shadowing a robotics guy at work recently and he gave me a USB with the installation files (parts 1 through 8 of Revision N) for Roboguide (30 day trial) so I can do some practicing on it. Every time I try to create a new work cell or create from a backup, I get this error about something to do with I/O. I've uninstalled an reinstalled (as administrator) several times, but I continue to get this error. I have a second image of the error that comes right after the picture included that mentions:
    "RGCCommonWorkcellWizard.RGCWorkcellWizardIntereface_CreateWorkcell
    Object reference not set to an instance of an object.
    at
    SimPRO.RGCCommonWorkcellWizard.RGCWorkcellWizardInterface_CreateWorkcell()"
    I feel like there is a file missing somehow, but if anyone has an idea of what could be causing this issue, I would appreciate any help.
    Images
      • 15.21 kB
      • 492 × 451
      • 10
  • Swicke
    • October 2, 2020 at 11:14 PM
    Here is what is on the USB:
  • jmd2777
    34
    193
    • October 2, 2020 at 11:25 PM
    The file sizes are correct. I have had corrupted Roboguide installs in the past. Maybe try reinstalling. Make sure to run the install as administrator.
  • alive15
    15
    160
    • October 2, 2020 at 11:44 PM
    Maybe try extracting with a different software other than WinRAR? Otherwise contact FANUC, they should point you in the right direction iA
  • Swicke
    • October 2, 2020 at 11:47 PM
    Quote from jmd2777
    Here's something I don't quite understand: most of the files inside each of the 8 parts are identical, so do I need to put them all inside the same folder and replace any of the duplicate files? I'm not used to having several installation parts for a single program, so I'm not sure what the main folder structure should look like for this program.
    Thanks for the reply.
  • Swicke
    • October 2, 2020 at 11:55 PM
    Quote from alive15
    Thanks for the recommendation. I'll try extracting with 7zip and see what happens.
  • jmd2777
    34
    193
    It is a self-extracting afrchive. You should not manually extract the files.
    To install, part01 through part08 should be in the same folder. Then right-click on SFTROBOG9DVD_Rev.N.part01.exe and select "Run as administrator". It will extract the contents to the same folder.
    In the extracted files there will be setup.exe. Then right-click on it and select "Run as administrator".
  • Swicke
    • October 3, 2020 at 3:17 AM
    Quote from jmd2777
    I uninstalled everything and followed what you said, but I still get the same error. My install folder looks like this after everything is done. Sounds like I'll either have to contact FANUC or have him give me another USB with hopefully all of the correct files.
  • RobotCoder
    5
    39
    • October 3, 2020 at 7:40 AM
    I know this might be a far stretch to do, but, take these files and try the install on another computer. This will tell you if it's PC based or install file based.
    Edit: In addition, anytime you are working with RG specific applicational events, copy from USB and store locally. This might suppress some issues as well.
  • Swicke
    • October 3, 2020 at 9:51 PM
    Quote from RobotCoder
    I appreciate the reply! At this point, I'm just going to wait until Monday and talk with the robotics guy and see if he can get me the correct files for the installation. I was hoping to get some practice with the software over the weekend, but it looks like that will have to wait.
  • retobor
    17
    205
    • October 5, 2020 at 1:37 PM
    • #11
    Another item to consider which hasn't been mentioned is your firewall settings. RG communicates to robot server which will go through firewall to communicate to dependent programs.
  • RobotCoder
    5
    39
    • October 5, 2020 at 1:41 PM
    • #12
    Quote from retobor
    This is actually a really great point. Firewalls even local can block some items. Good catch.
  • Swicke
    • October 6, 2020 at 2:54 AM
    • #13
    Quote from retobor
    Thanks for the recommendation. I was able to add roboguide.exe to the firewall exceptions, but still getting the same error that prevents me from opening a work cell. I don't even know where the "FRCIOCommonClass.CreateSeg" file is or if I even have it. I've tried searching for it but nothing comes up. Unless It's a specific string of text in a certain file that is somehow missing...not quite sure how that would go missing, though. That error in the first photo doesn't really make sense to me. :grinning_face_with_smiling_eyes:
  • Swicke
    • October 6, 2020 at 2:58 AM
    • #14
    I appreciate everyone's help. I wasn't expecting to get much support with my problem, but am thankful for everyone's responses. I'll make sure and update when I do get the issue resolved.
  • Swicke
    • October 8, 2020 at 4:47 AM
    • #15
    Problem solved!
    I finally got the program to run properly and let me create a new work cell. It turns out my anti-virus was the problem all along. Honestly, I should have thought to check into this earlier.
    My anti-virus was preventing the program from creating a new work cell file in, what apparently is, a protected file location. For some reason, I wasn't getting notifications about these specific blocked processes. All I had to do was allow 3 specific applications to have access to a folder, and now everything works perfectly.
    Hope this post can be of some help if anyone has a similar issue in the future.
Similar Threads
  • Software Request to Fanuc - the robot forum bugs and wish list
    • Werner Hampel
    • August 17, 2019 at 11:12 AM
    • Fanuc Robot Forum
  • Error open workcell Roboguide
    • M1chilino
    • August 4, 2020 at 9:37 PM
    • Fanuc Robot Forum
  • Roboguide workcell built by earlier version cannot be open normally
    • lavaman
    • September 20, 2017 at 12:57 AM
    • Fanuc Robot Forum
  • Roboguide load add-ins after creating workcell
    • Tico
    • December 8, 2017 at 2:43 PM
    • Fanuc Robot Forum
  • Roboguide keeps breaking on our computers (can't create a second robot)
    • dohlfhauldhagen
    • March 9, 2017 at 4:31 PM
    • Fanuc Robot Forum
  • Roboguide adding 7th axis (rail unit)
    • Errorcode
    • April 3, 2020 at 9:59 AM
    • Fanuc Robot Forum
  • MOTN-017 error
    • mjktech
    • May 23, 2017 at 5:41 PM
    • Fanuc Robot Forum
  • workcell
