Guys, I had pushed button clear instead off select, so in my weld proces, now I dont have option Setup (no weld) and I cant manually do nothinf on fronius controler. What can I do?
See picture
See picture
The selected mode is job mode switch to manual mode then you can run off of the fronius control pad.
If you have jobs created and you normally run in job mode then switch to the job that works or create a new job in manual mode.
Last but not least Fronius does have good support when you can reach them.
Its quick fix don't worry. Just got to System variables - $AWEPRGSEL. Now hit details and in the array choose the [Equip number , Process number] that you wiped out.
Example: [1,4] would be for setup in Fronius.
I hace choose it, but cant do anything?
See pic
Ok, I figure it out.
Have to put $prg_cmd 2 instead of 0.
