Hello friends, I want to release the breakes for j2 and j3 on the arm and also the external 1 and 2, I already read all of the information about this in the forum but nothing worked to me, the only alarm I have displayed on the tp is srvo-075 pulse not established in each of the axis that I mentioned before, I tried resseting pca and powering off and trying to rotate some deegres these axes to eliminate the fault but not able to jog, so I want to release the breaks to move these axis manually and then see if it allows me to jog, please HELP!! thank you in advance !
How to release brakes on a fanuc rj2 arc mate 100i
Plasmatrack -
July 23, 2020 at 8:50 PM -
You will need a brake release unit, or you could rig up something to feed 90vdc to the brake. There is no built in function to release the brakes.
Not trying to be a wise arse....
You are trying to jog in Joint, right? You can only jog in joint with that error.
Thank you pdl, that is what I needed to know, I tried many ways using variables, is good to know that this robot has not that function.
Hello Doctor_C yes, I'm trying to jog the robot in joint coordinates, thank you
Hello guys, I just released 3 of the breaks using a 90vdc power source to an a3/300 and other two a6/2000 servomotors, the problem now is with a1/3000 it has a different kind of connector, I tried connecting 90vdc to pin 5 and 6 on the connector but it didn't work, do you know what is missing? I attached photos from the connectors.
diagram
