Hello Everyone,
Normally from grippertech package I can do only the following functionality : if I push the key, the output is set, and if I push another key the output is reset…
But I want to have the following functionality :
- I push the key and hold it, the output is set to TRUE.
- I release the key, then the output is set to FALSE.
which means i want to set the output to true only when the key is pressed. Is it possible to make this functionality through GripperSpotTech ?
