"D" Batteries for Fanuc M70iC
  • alive15
  • June 22, 2020 at 11:39 PM
  • alive15
    15
    161
    Good afternoon all,
    Our robot uses four D size batteries, Part #A98L-0031-0005 from Fanuc. Does anyone know whether these are standard alkaline batteries I can buy from Wal-mart? I have not had the chance to open the battery case for myself due to our tight production schedule.
    Also, would lithium batteries be the better option and last longer compared to alkaline? We are looking at changing these batteries once a year on our annual preventative maintenance (PM) schedule. Thanks!:thumbs_up:
  • RobotCoder
    5
    39
    • June 23, 2020 at 12:50 AM
    Any D Batteries should be fine. I can't answer the below question, maybe someone on the forum has seen performance improvements of one other the other.
    Quote from alive15
  • keyboard7
    162
    • June 23, 2020 at 1:28 PM
    Use a name brand alkaline battery, don't skimp. Been seeing posts about batteries going dead and losing master.
    We never!!! turn the power off to our robot controller, we just power it down with the off button.
    When you turn off the large switch used to lock out the robot to maintain or repair it, it goes onto battery back up.
    the only time you want to be on battery backup is when the power is off to your building.
  • alive15
    15
    161
    • June 23, 2020 at 4:08 PM
    Sounds good, I will look at getting Duracell or Energizer. Thanks,
  • pdl
    270
    1,547
    • June 29, 2020 at 8:16 PM
    i prefer to use "industrial grade" batteries, as I have found them less likely to leek. Fastenal or Grainger can supply them.
  • alive15
    15
    161
    • June 29, 2020 at 10:34 PM
    Thanks for the reply pdl, I bought Duracell's "Procell" D size battery. I am unsure if they are industrial grade or not, but praying they last at least one year, since our Preventative maintenance routine calls to change them out once a year.
  • pdl
    270
    1,547
    • June 29, 2020 at 11:47 PM
    Procells are industrial. Just make sure to change them with the power on :smiling_face:
  • RobotCoder
    5
    39
    • July 1, 2020 at 8:47 AM
    Quote from alive15
    Battery technology changes are minimal at best. You should follow PM schedules. - It's all the same behind the hood. - In all actuality, unless you're power cycling the robot consistently (or keeping the robot offline for long periods of time). Just watch your alarms. You will get an alarm when it's time to change.
  • batteries
