Data Weld Procedure
  • carlrodr
  • March 4, 2020 at 10:18 PM
  • carlrodr
    Good afternoon
    I would like to know if there is a way to extract the DATA Weld Procedure values, if anything:
    1. save them in a system variable
    2. we can extract them by karel
    3. If they can be monitored in any way.<img src="https://www.robot-forum.com/attachment/25933-data-weld-procedure-jpg/?thumbnail=1" class="woltlabAttachment" data-attachment-id="25933" id="wcfImgAttachment0">
    Images
      • 154.58 kB
      • 1,280 × 720
      • 73
  • Lemster68 March 4, 2020 at 10:30 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum Fanuc Robot Forum.
  • dha
    29
    397
    • March 5, 2020 at 11:02 AM
    You can use GET_VAR KAREL function to read all parameters.
    If you have V9 robot controller you can even do it in TP program.
Similar Threads
  • Transferring Weld Procedures/Schedules
    • brian.b
    • August 29, 2018 at 9:46 PM
    • Fanuc Robot Forum
  • R30iA Controller teachpendant program password protection procedure
    • marun_1987
    • January 27, 2016 at 4:19 PM
    • Fanuc Robot Forum
  • Weld Schd query - Not able to get WFS column and Trim column in Weld Sch window
    • sanjay bisht
    • February 17, 2020 at 1:21 PM
    • Fanuc Robot Forum
  • Clamp force adjustment and weld programming
    • mike.stotts
    • January 16, 2020 at 5:27 PM
    • Kawasaki Robot Forum
  • ARC-013 No arc after 1st weld
    • BORObot2018
    • September 17, 2019 at 7:34 PM
    • Fanuc Robot Forum
  • Spot welding pressure
    • belnea1
    • March 23, 2019 at 10:44 AM
    • Fanuc Robot Forum
  • Question on BullsEye Set-up procedure
    • pb5024
    • August 28, 2018 at 5:20 AM
    • ABB Robot Forum
  • Weld Procedures for Lincoln Fanuc
    • andrew.hegerty
    • August 27, 2017 at 7:52 AM
    • Fanuc Robot Forum
