Dear sir ,
Kindly post anyone the procedure of password protection only for programs
Regards
M.Arunkumar
Dear sir ,
Regards
M.Arunkumar
Hi marun_1987
You can lock write access only to the program, but there isn't a password protection only for programs.
You can set password that determine the level you logged in the system. This resctrict the possibility to modify all the items of the system.
Dear sir
Pls give the step by step procedure for level wise password lock
Regards
M.Arun
Have you got the manual?
No sir pls help
MENU ---> 6 SETUP---> PASSWORD--->F2 LOGIN ..... then enter username and a password for install level (with controller R30iB or R30iA first i don't know if is the same)
Then in the same page you can set various username with different level.
With level setup or program or install you can modify program.
With operator level (when you are logout) you can't modify program.
Dear sir,
Thanks for your help..
Also pls explain about the levels and its restrictions briefly pls
It will better for me to configuration...
Kindly help
Regards
M.Arunkumar
That's for R30iA:
Install - Assigns user names, passwords, and levels. Clears usernames and passwords. Disables and
enables the Password Log. Sets the number of Password users in the system. Can perform all Setup, Program, and Operator operations.
Note There can be only one install user.
Setup - Performs operations typically used to set up your system.
Program - Performs more advanced operations.
Operator - Performs basic operations.
User Defined - Performs basic operations unless defined otherwise in the Password Configuration File.
Also take a look at the file attached
Hopefully it helps
Greg
Dear sir,
Thanks a lot ....
Hi. I'm new here. We are trying to install passwords on our R30iB and not sure where to go to User Defined - Performs basic operations unless defined otherwise in the Password Configuration File. What all can we defined for operators. They still need to make weld moves but we don't want them to change the weld data. Any help. Thanks steve53
Hi here is some example of configuration file:
<?xml version="1.0"?>
<!-- Password configuration file -->
<PASSWORD>
<!-- Level name -->
<LEVEL level="8" name="INSTALL"/>
<LEVEL level="3" name="Operator"/>
<LEVEL level="2" name="CustomerAdmin"/>
<!-- Default Menu type. Full = 0, Quick = 1, HMI Full = 2, HMI Quick = 3-->
<DEFMENU level="3" type="1"/>
<DEFMENU level="2" type="0"/>
<!-- Define default screen for logon-->
<DEFSCREEN level="2" sp_id="64" scrn_id="1"/>
<DEFSCREEN level="3" sp_id="0" scrn_id="1"/>
<!-- Define which screens operator level is allowed to access/edit-->
<SCREEN level="3" sp_id="98" scrn_id="1" access="1" rw_access="1"/> <!--DI/DO -->
<SCREEN level="3" sp_id="107" scrn_id="1" access="1" rw_access="1"/> <!-- RI/RO -->
<SCREEN level="3" sp_id="23" scrn_id="1" access="1" rw_access="1"/> <!-- Registers -->
</PASSWORD>
In here you can define what active user can do. The list of pages you can found from http://"robot ip addres"/MD/TPMENU.DG
Hope this helps
Is the password something that has to be added because i tried to look it up on my pendant and didn't see password on the setup tab. If anyone could let me know because i have had a case of someone deleting lines.
its a paid option from FANUC. It does not come standard
Password Protection
RTL-J541
hi all...
I came across this issue at my plant as well. The only question I have is if there is a way to put all the passwords on a single USB or something, and then be able to dump it into each Robot. We want to set up a profile for each Tech plus engineering. and also have around 85 robots to install this on
Hola a todos buen día en mi planta me encuentro con un problema similar los operadores han borrado programas por manipular el teach pendant al alguna forma de poner password con ciertos privilegios para operar el robot alguien me puede ayudar por favor Gracias
