Hello.
I have a kcp2 pendant without cable and plug but i found a piece of cable from an other vkcp2.
What is the type of plug that goes on krc2 ?
How can i search it to order it ?
Also where can i found the pinout of this plug ?
Hello.
dont know either but here is pinout of X19 interface on the cabinet side.
On KRC2, X19 is a circular connector from Interfontec.
Yes i know that pinout but i want also the pinout inside kcp2 plug.
To make vkcp2 to kcp2 conversion must change the selector smd resistor position & change mode selector switch correct ? Or needs some other modification ?
Another prob i have is that i removed kvga2 very carefully and stored it for about 6 months inside
ESD bag and now does not seem to work... I have read that is prone to ESD damage
and i carefully managed for that... i hope that is not damaged by ESD but there was not properly seated in pci socket.
But if is damaged by ESD what is the component that goes bad because of ESD ?
Which intercontec connector is exactly to order it?
I found these
https://www.servoconnectors.co.uk/pdfs/A_twintecb_en.pdf
https://www.mouser.com/pdfdocs/Intercontec_623_DE_EN_w.pdf
but iam not sure
Thanks.
