I m new to FANUC ,and have doubts in setting up DI/DO range and their start point and SLOT as well.
Can someone please provide detailed structure to understand all these and how to set them.
Thanks in Advance.
Please help.
Thanks in Advance.
Please help.
The rack depends on which device/method you are planning to use for your IO.
The slot is which "card" you are setting the Inputs or Outputs to.
A "Model A" setup with one 16 bit input and 16 bit output would be.
Inputs
Rack 1 Slot 1 Start 1
Outputs
Rack 1 Slot 2 Start 1
Ethernet is Rack 89
And what about range like 1-16 or something else like that
Range is where you want the individual bits addressed to. Lets say you have one model A input card with 16 points, that could be mapped to 1 - 16. Now lets say you want to add another 32 points over Ethernet I/P, those could, but don't have to be addressed to 17 - 80.
Then when programming, if you wanted to look at you model A I/O you would use DI[1] through DI[16], or DI[17] through DI[80] for your Ethernet bits.
Thank you so much for such a detailed description.
One more thing I want to know is How to do I/O configuration ....a step by step procedure
