Weak spindle holder?
JohnKU -
December 4, 2019 at 7:35 AM -
The router bit looks very long. Can you get a shorter one, ideally as short as possible while still long enough to do the job.
Hello , Your spindle mount looks good. But if you can cross verify maximum payload when you are performing your routing work.Like depth of cut is more that may also create vibration. The spindle should be as close as possible. As center of gravity and inertia will come into picture.
- Shortening the length of mount.
- Shortening the length of router bit.
- Dampers between mounting.
HawkME.
Unfortunately no. Does not allow the height of the processed model.
Did you try to change process and do multiple runs with different bits? in example first run with shorter bit, then do final with long. It may increase you cycle time, but have a change to reduce vibration issue.
Personal opinion: based on weight of the spindel I might go with 6mm tube for spindel mount. In your case you have 4mm plates that also are not welded on ribs.
I have KR150/KR180/KR210 and 2 motors 22kw-100kg-2300rpm/12.5kw-70kg-2000rpm.
I want to put cutting disk in motors and mount motors to robots.
Will KR210 have problem with 100kg or 70kg motor mounted to the wrist ?
