Dear All,
Robot Status -> Software Re-Install after Cold start
DSQC 328 I/O Boards configured (MS/NS lights flashing correctly)
How do I map the I/O on the DSQC 328 I/O board
Thank you
Dear All,
Thank you
If it's a reinstall, can't you load the EIO.cfg parameter file from a backup to get the mapping back?
Does the current program already have I/O instructions that are causing errors due to the I/O not being mapped?
Are you starting from scratch?
Hi Skooter,
I am starting from scratch.
Appreciate if you have some tips.
Thank you
Shane
The controller version you are using is necessary S4, S4C, etc.,
If the DSQC328 is correctly defined as a unit in the I/O parameters, the NS (Network Status) LED should be solid green.
Do you have a User's Guide for the software version installed? That may help you understand some of the answers you may receive.
It could save time if you attached the EIO.cfg file from the parameters directory.
