Primero, con el teclado conectado de 5 pines. presione la tecla del logotipo de Windows ... (se abre el Explorador de Windows). en la siguiente carpeta: (carpeta kuka data krc (modelo de búsqueda abierto mada marca los 4 archivos con las teclas copia los 4 archivos con (ctrl + c). Salimos y buscamos la carpeta krka del disco kuka buscamos la mada . pulse el interior (Ctrl + v) pegado, se nos pregunta si aceptamos el cambio, apretamos (pestaña) en la pantalla principal buscamos arranque en frío y apague el robot, de nuevo al iniciar se cambia el modelo de robot.
I will explain how to change the mada. so that everyone can change it easily
manolomaravillas -
September 26, 2019 at 9:50 PM -
This is English forum section. If you want to post here, post in English. You have been warned already here and here. This is the third and last warning.
Courtesy of Google translate:
"First, with the connected 5-pin keyboard. press the Windows logo key ... (Windows Explorer opens). in the following folder: (kuka data krc folder (open search model mada dials the 4 files with the keys copy the 4 files with (ctrl + c).) We go out and look for the krka folder of the kuka disk we look for the mada. press inside (Ctrl + v) pasted, we are asked if we accept the change, press (tab) on the main screen we look for cold start and turn off the robot, again at the beginning the robot model is changed."
