only alarm on the robot.
fault list says something about low signal at $MOVE_enable input.
what can cause this?
check input... what input?
cant jog the robot at all.
KVR C1
KR200
year 2000
sorry for this easy thing but iam a beginner
KVR C1
KR200
year 2000
what is the system software version?
it could be any input, KUKA allows flexible mapping of signals
if you login as expert, there should be menu such as Configure>IO>AutoExternal then you should see the input assigned to this signal.
Cant click on the I/o. Nothing happens
Found this.
Not sure what to do from here
Possible to change something in the I/O config file?
Do NOT post such large attachments. Read READ FIRST.
Are you SURE you are logged in...?
Sorry posted from the phone didnt think of the size.
Expert yes.
Note that the robot is not used for origin purpose. Was a spotwelder now not really anything yet.
Wanna learn to use it before i find a pupose for it.
Might be some of the IO config file that makes failures?
well it is input 16 so you need to ether make it TRUE or remap it to input 1025, as an expert of course
If i remap it.
Is it in file i/o config?
[size=2]sigh, read more and pay attention. [/size]
[size=small]as mentioned read READ FIRST. I mean it...[/size]
[size=small][/size]
[size=small]stop asking silly questions that can easily be answered by checking manual or searching forum. if you need a lot of hand holding hire someone. forum is for people that can read, think and do things themselves.[/size]
Quote[size=2]it could be any input, KUKA allows flexible mapping of signals [/size]
[size=2]if you login as expert, there should be menu such as Configure>IO>AutoExternal then you should see the input assigned to this signal.[/size]
