Hey i'm in a Yaskawa GP12 and my controller is the YRC1000. I want to do a list of outputs to activate them without entering in the job, how i do that?
thanks
thanks
Manually, from the main menu, tap In/Out, then tap Universal output, cursor to the indicator of the output you want to change the status of and hold the inter lock key and press select to change the status of that output. You can also set up Key allocation to set an individual output on or off or a group of outputs to a value.
Automatically, you need the System job option bought from Yaskawa and to write a system job to change the status of the outputs you like.
In play mode the program do not run the lines that have out/in, so i need to purschase something from yaskawa? thanks
You can push "INTERLOCK + NUMBER" to set output ON/OFF but, you need to set it first.
Try S2C397=1. Under whatever the application icon is will be I/O Variable Customize List. You can set the addresses up there.
