Hi guys,
I have encountered a strange occurrence when using the vision system. The system is failing an image which is within all the limits set in the program. I've gone through the other limits and tools and I have checked each individually The problem seems to be with the scaling limit. The limit is set from 98 – 102, the scale is reading 98.5 and the part is being failed. When the limit is changed to 97 – 102 the part passes. I haven't come up with any logical explanation as to why this occurs so hopefully someone can provide some insight.
TIA
Edit: Fixed wording
