Fanuc Profinet configurations
  • naruto_yyc
  • June 11, 2019 at 1:13 AM
  • naruto_yyc
    Hi Guys
    I have some issues with profinet configuration
    Siemens step 7 v5.5
    Fanuc robot profinet card cp1616
    I have 8 byte safety
    16 byte DI
    16 byte DO
    I setup DI and DO. No error.
    But I have safety comm error 1.1
    I put Cp1616 at slot 0
    safety at slot 1
    DI at slot 2
    DO at slot 3
    So far slot 2, 3 are ok, (no mismatch )
    But safety are no ok,
    F number is matching between robot and plc side
    Is there’s anyone can help me on this, I don’t know what I miss. It’s the first time I am configure profisafe for robot
  • byrol
    13
    5
    347
    • June 11, 2019 at 11:22 AM
    Maybe he can give you an idea..
    Images
      • 81.71 kB
      • 471 × 518
      • 295
    Files
    profinet 1.jpg_thumb 25.19 kB – 578 Downloads
  • Robot Programmer
    5
    26
    • June 11, 2019 at 2:51 PM
    I use:
    Images
      • 9.43 kB
      • 599 × 189
      • 188
    Files
    Untitled.png_thumb 10.01 kB – 542 Downloads
  • scotty
    43
    5
    497
    • June 11, 2019 at 3:01 PM
    Just to let you know that Profinet and ProfiSafe are not the same. ProfiSafe is based on Profinet, but it's a little bit different.
  • naruto_yyc
    • June 11, 2019 at 4:01 PM
    Quote from byrol
    Thank you for your replying
    I did the same thing as your picture shows
    But for the safety configure
    robot side
    I put safety on slot 1,
    module id 0x0001008
    subslot 0000001
    and also change DCS to 8 byte input and 8 byte output
    PLC side
    HW config safety on slot 1 PS 8byte
    So is there any thing I missed or mistake ?
  • naruto_yyc
    • June 11, 2019 at 4:02 PM
    Quote from Robot Programmer
    I use:
    Hi
    I have not set up DCS IO yet
    after I configure PLC HW and robot
    I still have issues for profisafe comm error 1.1
    thanks
  • naruto_yyc
    • June 11, 2019 at 4:03 PM
    Quote from scotty
    Hi
    would you mind to tell me what's difference for configuration
  • scotty
    43
    5
    497
    • June 11, 2019 at 5:48 PM
    Quote from naruto_yyc
    Hi
    https://www.youtube.com/watch?v=S3tbB9-8X4Y
  • byrol
    13
    5
    347
    • June 12, 2019 at 7:43 AM
    I've done a similar work on a robot I've configured before. It's not something I remember a lot. I took advantage of the document I shared your picture with. However, both the robot side and the PLC side of the security card "slot 0" i remember introduced. I remember starting the normal "Di/Do" configuration from "slot 1". I'm sorry I can only help you at this level.
  • bidzej
    23
    592
    • June 13, 2019 at 9:29 PM
    did you assign the F-address to the ProfiSafe module? Did you configure it in the robot's ProfiNet Safe settings?
  • AYSE.G
    • January 13, 2021 at 11:11 PM
    • #11
    Dear naruto,
    I have same problem with you. how did you solve it. if you can explain, I will be happy.
    Thank you
  • Fernando Sanchez
    26
    • August 6, 2024 at 5:14 PM
    • #12
    I'm on the same way, does anyone find an answer?
