I need to put some .txt file into fanuc FR: directory. By default Then I connect to robot FTP server I in MD: directory. How to configure default directory to be FR:?
I need that, because file must be transferred automatically for example some PC based program save files to fanuc FTP. So I can't use any FTP client for transferring file except windows explorer
Fanuc default FTP server configuration
bips -
June 4, 2019 at 11:00 AM -
Use the Change directory command followed by the directory you want.
cd fr:
HI, Yes I know that this will work in FTP client program,
But I want to add it as a patch to Windows file system -
I'm not 100% sure but I don't think that is possible in the using Windows File explorer. You will probably need to install a third party ftp client to achieve what you want.
I'm not 100% sure I understand what you're trying to do, but this might help:
make a batch file, putTxt.bat. It has one line:
ftp -i -s:putTxt.ftp
then make a file in the same directory called putTxt.ftp:
open <robot IP address>
<Username>
<Password>
binary
cd fr:
put <filepath of file to upload> <filename you want on the robot>
disconnect
quit
