You need new registers, i.e. PR[11] to PR[16] and record there your positions you want to work with (what you currently recorded in P[1] to P[6].
Then add at the beginning of your program, before label 1, PR[1] = PR[11], PR[2] = PR[12] ... PR[6] = PR[16].
That way those number will never change and every time you start the program it will start from the same positions
Exactly... thanks for the assist TexDino
In this way, the only way the original values should change is if you have to reteach your points.
Sent from my iPhone using Tapatalk
