Hello!
I am a student, work with EthernetKRL and I have a problem.
The documentation says that there are special examples for working with this option. But in my robot someone deleted them.
Anyone can send me EthernetKRL_server.exe? I will be very grateful.
Ethernet KRL
Valfoland -
December 10, 2018 at 4:26 PM -
I am not sure you have provided sufficient info. I would suggest that you read "READ FIRST" that is pinned on the start page here.
Ethernet KRL is just an optional technology package from KUKA with which you can communicate through an Ethernet KRL interface. This means you can use it to send or/and receive XML or Binary data from an external system as a client or server.
Communication is done using the TCP/IP protocol. It could be configured setting the IP addresses, port numbers and so on. It is not an .exe file or software which you can install and run.
If this package is missing on your KUKA then it is either it has not been installed or uninstalled. -
read pinned topic READ FIRST
check D:\TECH_OPT
contact KUKA
