Hi all,
I want to make a simulation in robot studio, with a S4C+ backup. An ABB expert said to me it's possible, but i can't find how to do. Anyone can help me ?
Thanks in advance
Hi all,
Thanks in advance
You cant exactly load an S4C+ backup in a 5, but you can make an identical virtual system, i.e. same model robot, load in your programs and modules, then change the EIO file to the same format an IRC5 uses. It takes some time to do because little things changed in the EIO wording.
Yes, this is what the expert explain , but when i want to load the backup, robot studio don't find anything, so, is there something special to do ?
you can't load the whole backup, you'll have to load each file individually
OK, thank you both.
To change the EIO file, is an example of EIO 5 is enough, or is it more complicated ?
Or You can also try RobotStudio 4.
It way more primitive than RobotStudio 6, and it isn't supported by ABB anymore.
But You can create a exactly copy of Your system.
You can download RS 4 here.
I can't use RS4, my boss want me to use the last version and i have restrictions for download. I try to make the good changes in EIO cfg.
Thanks all for the help
