hi,
Im looking for a button or a function for read program when robot run with a DX200. The same function like fanuc with look button.
hi,
While the master is running, you can use the Page button to toggle through the running sub programs
I push "page" button (top of teach) when the master is running but nothing happens.
The Page key only works if Concurrent Job is turned on AND there are multiple jobs running at the time.
I don't know what the Fanuc Look button does. Can you describe it?
You can always see what the active job is by going to JOB in the Main Menu and JOB in the sub-menu.
i'll do try to explain the look button with my poor english!!
The Look button freeze the screen in the current programm.
it is then possible to navigate in the program to read it when the robot work.
i just want to be able to read a program without being in teach mode
Can't do that with a Motoman robot.
Ok thanks for answers
