Hello, I apologize for bad English, but I use a translator
I bought robot sk6 MRC controller with Fronius TRS 330synergic welder. The system works until the last edition and has no problems but:
- how can i adjust the cable speed
Валкамар
Валкамар
You will need to adjust the wire feed speed in the job in the Fronius welder. You won't be able to adjust it on the robot itself.
Регулира се от токоисточника
Как са нещата, регулирани от източника на захранване?
With a Fronius welder and an MRC robot you must run the welder in job mode. The robot then only digitally selects the job you want to run. So to change the wire feed speed you must change the speed in the job you are calling.
