Maybe I am doing this wrong?
After completing the payload identification calibration on an R30iB-LR mate 200iC it tell me it's overloaded. The estimation came out to 0.52 kg. This Doesn't seem right to me.
This robot is a 7Kg robot. The EOAT is 12.5 lbs. Yes it is close to max, or is it over?
Did I calibrate is incorrectly? All I entered was the G1 payload EOAT W/O part as 5.7kg and G2 payload as EOAT w/parts as 6.5kg. All inertia were 0 before the calibration.
Can anyone advise if my manually entered values are effecting the Cal?
Thank you.
Payload to high
bill4807 -
July 21, 2018 at 3:55 AM -
You are not telling us if those 5.5 kg are right at the face plate or 1 meter away from the face plate or what kind on distribution
It is a dual arm gripper. Two festo HGDT-50 mounted side by side on a flat plate about 12"in length and 4-5 " depth. This flat plate is directly mounted to J6.
Do you have they payload checker excel sheet ? I have one at work, I can check that Monday
That will give you a better idea of your issue -
We can do all the math we want but at 7kg robot manipulating a EOAT 6.5 kg is a tough one, specially with your eoat dimension
Can you make the plate lighter, drill holes, etc ? -
No I do not have the payload checker.
I will look into options to make it lighter on monday.
Thank you for the help -
I'd be interested in obtaining the payload checker as well.
We are using an LR Mate 200iD/7L with 7kg payload and a dual gripper hanging off the end. Our worst case is a 6.38kg load and I calculated the inertia's using our solid modeling software. When I manually created payload's it warned that it was near the maximum but everything works ok for us.
As I recall, in order for the payload estimation to be performed correctly, it must first be done without any load, then with your EOAT attached. Has the estimation been performed without any EOAT?
Would also be interested in an payload checker.
