Hey guys, I'm facing this situation where I have to remaster the robot axis every time the controller is turned on. At first I was sure the problem was the battery, but now it1s still happening even with brand new ones. What can it be?
It's a KRC2 controller. Thank you guys
I need to remaster the robot axis every time the controller is turned on
raulboter -
July 10, 2018 at 1:26 PM -
Are you getting any warning messages from the controller while it is powered up, or during reboot? Did you charge the new batteries for 12-24hrs before shutting down the controller? Have you checked the voltage on the charging circuit?
If the batteries are ruled out, then the next most probable cause is that the RDC board's EEPROM has reached end of life and needs to be replaced.
The RDC2 has a limited number of writes to the EEPROM and can require changing. Or can just be a bad RDC2.
RDC 1 has limited writes i dont belive the RDC 2 has this problem
