Helo everyone,
I have an issue that I havent been able to figure out.
I have a R-30iB robot. I have a DCS zone. I can trigger a safety I/O when rhe robot enters/leaves the zone.
But I need to send this bit to a plc thru ethernet.
The question is, how can I send that bit to my PLC.
I appreciate the help.
FANUC DCS CPC thru ethernet
Davidmacias_87 -
June 21, 2018 at 1:48 AM -
Thread is Resolved
You need to pass it as a safety output or just a regular output?
regular output
thanks -
I want to assign it to a DO in rack 89
Thanks -
Helo everyone,
I appreciate the help.Which communication protocol do you have available?
What do you mean which communication protocol?
I just want it to activate a Do in rack 89 -
Map 1 or more DI's to Rack 36 slot 6 start point = CPC #
Then Use BG logic or IO interconnect set your DO from the DI.
Your DO is mapped to rack 89, EthernetIP communication protocol. Done.
I just want it to activate a Do in rack 89Do you already have an established link or are you looking to add an ethernet connection from scratch?
