Hi all,
Some background story:
I have a machine with two KRC4 robots in roboteam.
The slave robot batteries died.
The technical department tried to shut the slave robot down using "reload files".
After that the slave robot can't start anymore.
The smart pad is plugged into the master robot.
When I programmed that machine those robots had a problem where the "reload files" button could leave the robot completely unconfigured.
Current status:
I've tried to remotely connect to the machine.
I can ping the master robot and the PLC.
I can't ping the slave robot.
I've asked the technicians at customer's place to shut the machine down, unplug the smart pad from the master robot and plug it to the slave robot and start the machine again.
Once the machine has been powered the smartpad showes a display with the man with the safety belts in red, the IP button in yellow and the robot in red. All in a completely red stripe that crosses the display from left to right just on top of it.
The message that can be read there is:
Could not set IP address.
Unable to configure IP address automatically.
How can I configure an IP address to be able to keep configuring the slave robot remotely?
Thank you very much!
