hi guys
when i want to initiate my robot and press the enabling switch on KCP , fault message "active commands inhibited" popup. actually i can see the contactor on the KPS 600/20 does not actuate, though none of the red lights on KPS are" on" , and when i press its coil manually, emergency stop occure,. whats the reason?????????
regards
faults when initiating
mesut9270 -
March 12, 2018 at 5:30 PM -
Read and follow: https://www.robot-forum.com/robotforum/kuk…rum/read-first/
Any other messages?
Robot integrated in a cell or standalone, did he work properly before, .... -
yes it worked before
if drives are not on, you cannot move robot... what other messages are there?
all the green lights of the six drives are on, i.e they are in good mood, the green light of rectifier is on as well. but when i press the enabling switch on KCP the contactor on rectifier does not actuate.
the messages was like this:1-PM1 under 22 ( i checked with multimeter it was 27 v)
2-dse-rdw transmition error
3- an error about K1 (contactor, i do not recall preciously)
4- when i pressed coil of K1 manually it errors about ballast. -
don't look at LEDs on components inside cabinet when teachpendant is working.
is the robot connected to controller? -
yes, of course its connected -
hehe, it may be "of course" to you but you would be surprised how many times that fixed the issue...
but the RDW-DSE transmission error is telling that robot cannot talk to RDC (RDW). this communicaiton is important milestone to get robot operational.
hehe, it may be "of course" to you but you would be surprised how many times that fixed the issue...but the RDW-DSE transmission error is telling that robot cannot talk to RDC (RDW). this communicaiton is important milestone to get robot operational.
its probably from that connection, i have not checked it yet, because all connection are as the same as it worked before, but when the robot stopped working the first thin i did i, changed the rectifier but it did not changed any thing,
i shall try that tommorow
