Hi
One of my colleagues noticed the following: When he writes a program in WorkVisual, he can generate code just fine. But when he deploys the program on the robot, he gets a lot of syntax errors. It seems that the robot is a lot more strict in its syntax checking than WorkVisual is. He also said that it is as if it only compiles the active file in WorkVisual, it does not perform syntax check in all files when code is generated. This is a problem if there are dependencies between the different files.
I can't remember the software version (KSS and WorkVisual), but it is a brand new robot, and he uses the WorkVisual software that came with the robot. It is a newer version than the one that can be downloaded from Kukas homepage.
Is this a known issue? It certainly makes WorkVisual less usable if that is the case.
/RoboticsMan
