Hello, I have an error with a red screen that says connection to KRC not Possible ! showing on my pendant, I have a KRC4 robot,
has anyone run into this.
Thanks john
KRC error
CTJohnB -
January 23, 2018 at 1:49 PM -
I didn't mention I did connect monitor and keyboard, and nothing on monitor, I'm wondering did hard drive get corrupted and may have to partition and format to reload software?
you need to connect monitor before booting up KRC
yes, I am aware of that, why do u always have to be so snide, novices come here for help and you chew them up and spit them out, a simple answer would do just fine thank you.
wasn't this simple answer?
if during boot monitor is not detected, video output is turned off and ... it may not detect monitor that is connected later (after boot...).
if monitor is powered up and connected to KPC before KPC is powered up and ... there is still nothing on monitor... you have a problem.
either it is video cable or monitor or KPC (if KPC, then most likely motherboard need to be replaced)
