hello,
(Disclaimer: very new at this). I am working with a KRC2 and using the KUKA|prc Grasshopper plugin to create the program code. When importing the code into the teach pendant (which is through a USB - Floppy disk translator), the pendant does not recognize the .src file as a program file and won't run it. I've attached a screenshot of the .src file sitting in the program folder, and I've also attached the .src code.
Any help as to why this isn't working would be greatly appreciated - thank you!
