I have been attempting to consistently Run programs through the SOP Auto Mode. I have been receiving the following error messages:
INTP-105 Run Request Failed
Cause: Program cannot be started
Remedy: Refer to error cause code. Use MENU to display the Alarm Log screen
MCTL-003 System is in Error Status
Cause: The system is in error status, therefore motion control was not granted
Remedy: Clear the error by pressing RESET, and try the operation again.
I have tried both Remedies with no success.
I am using PNS for my Program Select Method. Does anyone know if I could somehow manipulate the Base Number to be compatible with my programs? Or if I should change anything in my System Config?
If it is a Motor Control issue, could I edit motion groups to help? Is there a way to write program instructions that helps eliminate Motor control issues?
The strange thing is that it works sometimes without my explicitly changing a setting.
Please help! Thank you
