Hello.
I have problems with configuration simulated external axis (servozange based on SMC controller). By docs I have running Proconos, Ive made instalation of synchromove. I have in softplcint[23] actual position of the gun. Controlling by E1 softkey is not working. When I press for example "+" value of axis_pos.E1 is changing but gun not response. In configuration of external axis I have correct data for simulated axis. Proconos_IO.xml is configured right.
Configmon.ini installed and working but not get follow error for example.
Exchanging by profinet I/O works fine. I have signals from controller and can modify values and control gun by outputs but active positioning gun is not synchro with all of axis of robot.
System VSS 8.2.
Marek
