about the sequence of calibrating tool frame and base frame in KRC4
  • dinesh_harsoliya
  • August 10, 2017 at 12:45 PM
  • dinesh_harsoliya
    hello every one,
    i am new to use kuka robot . and i have a question in which sequence i should do calibrate the tool frame and base frame. till now i used numerical method first base frame and then tool frame , but when i wanted to use offset , robot program behaved in other way then i expected .
    i wanted to move all around the cube and later i gave offset of 100mm and expected to move robot in the previous manner just 100 mm in offset but it didn't .
    so it will be helpful for me if i can get an idea what i can do .
    thanks !!
  • panic mode
    1,281
    13,091
    • August 10, 2017 at 1:34 PM
    Order does not matter.... Normally you do not enter data manually, but measure tool and base. In that case one needs to measure tool first because that tool will be used to measure base.
