Hi All,
I tried to find PAUSE, and ABORT function from my inform list.
But there are not able to be found, is there any setting need to be done before seeing them in the inform list?
thank you.
Hi All,
thank you.
Is your language set to standard or expanded? if you have SubSet selected then these commands are not available. You can check by opening Setup > Teaching Condition > Language Level. These commands should be available in the Control menu of the INFORM list.
What generation is the controller?
i tried to use 'pause' in my program, it just didn't worked. it just skiped that step.
The PAUSE instruction must not have been executed. Was it in Teach or Play? Try again. Or you have logic that is skipping the PAUSE.
hi 95 devils,
its in teach mode, there is no logic. just to check every instruction i tried pause and it didnt worked.
So just a JOB with a PAUSE instruction right before the END instruction? In Teach are you doing FWD, Interlock+FWD, or Interlock+Test-Start? I can come up with a scenario where the PAUSE looks like it doesn't work.
If the PAUSE is directly above the END and the controller is set to CYCLE. The green START lamp would drop out and as long as I am holding the Enable switch and Interlock+Test-Start but servos would remain on when the controller executed the PAUSE or the END.
In teach FWD+Interlock I used
thats the problem. with interlock+FWD you will jump above the pause or any waiting-instruction!
In teach mode please use only FWD to run the program to the next waiting instructions or use interlock+Teststart for run the program.
