Hello. Is there a way to change the speeds from say step 11 to 33?
I've programmed a robot on R-J3iB controller with a milling motor to move at a specific speed but at some points it can go bit faster because of several reasons.
Change speeds in a program
KeesVos -
July 22, 2017 at 1:37 PM -
Thread is Resolved
This sounds fairly straightforward, can you post your code?
Are you using linear or joint moves?
All you really need to do is to change the feedrate, which is at the end of the linear or joint move instruction.
Yes it is that simple, however I am looking for a function to change a lot of lines in one go. In stead of going from line to line and change it manually.
I know this is possible at a Panasonic Robot for instance. -
You can assign the speed to a register.
Highlight the speed, above one of the function keys it will say indirect, press it and then assign the register.
Check MENU -> Utilities -> Program Adjustment.
There you can set offsets and speeds for desired lines and easily enable/disable them...
Though I prefer the aforementioned options better, the OVERRIDE command might be useful.
This sounds more like a utility than a programming method that is being requested, such as the utility that allows you to change an entire program or part of a program from running in one user frame to another. I do not know if such a utility exists for speed, though, since it can be expressed in multiple ways depending on the type of movement.
The MENU > Utilities > Program Adjustment did the trick. Thats exactly what I was looking for.
However I am also going to look for the register tip. In the end it might be more useful if I can change a lot of programs in one go, which I assume I can do with register.
