Build cable KSD
  • jesusvaricap
  • June 24, 2017 at 2:19 AM
  • jesusvaricap
    259
    Hello ,
    KRC2 , KSS 5.2.14
    I have the error of Disturbance on A6
    As say on the older posts:
    https://www.robot-forum.com/robotforum/kuk…56537/#msg56537
    https://www.robot-forum.com/robotforum/kuk…75103/#msg75103
    I do swapping for KSD , KPS , MFC , and the problem stills i think that the problems is cables bus KSD , from 1 side i have conector shielded Rj45 o pins , no problem to get this
    but , from the other side i have a connector 6 pins , here on Mexico i can not get this , maybe on Alibaba.com, maybe using cable UTP categry 5
    Im Glad to hear you advies , experiences about built my own Bus KSD cables
    Images
      • 89.57 kB
      • 516 × 919
      • 44
    Files
    IMG_0415.JPG_thumb 24.15 kB – 92 Downloads
  • Event Robotics
    8
    62
    • June 25, 2017 at 2:12 PM
    6 pin is called RJ-25
    You can get this online in many places.
    Rick
  • jesusvaricap
    259
    • June 27, 2017 at 12:49 AM
    thanks friend , but did you suggest to me build my own cables , there is "something especial "on the original cables from kuka ?
    BR
  • Event Robotics
    8
    62
    • June 28, 2017 at 12:49 PM
    Hello Rob,
    I checked it on one of our krc2 controllers.
    Its a normal cat5e cable, so you can make them yourself.
    Just make sure you got the color coding right on both sides
    There is nothing "special" about this cable.
    Use the proper tools and it will be fine.
    Rick
    Edited once, last by Event Robotics (June 28, 2017 at 12:50 PM).
  • jesusvaricap
    259
    • June 28, 2017 at 5:30 PM
    Hello Rick,
    I afraid to something happens , because a kuka Guy service told me that the cables was very special and difficult to made my own cables , for the special shielding , i look and just its a connector shielded.
    Well ... i try
  • Mansoor Ahmad
    72
    • July 7, 2017 at 6:53 AM
    Only care which you require is to take care about its shielding. use special shielding connectors (RJ45 and RJ20).
    If something goes wrong with the cable(except shortage) then nothing wrong will happen and system will not work.
    In my understandings, only critical thing is its proper shielding.
  • Robotmei
    203
    • August 7, 2020 at 8:39 PM
    Hello
    I am looking for any information like part number of KUKA KSD-16 six and four pins connector. can anyone help?
    Regards
    Images
      • 178.04 kB
      • 1,600 × 1,200
      • 8
Users Viewing This Thread
  • 1 Guest
