Hi.
I have a little problem when i take a backup using USB stick.
in Backup/RAPID/TASK1/PROGMOD there is 9 modules.
When i make a backup to my USB memory stick some modules are missing, the missing modules varies from 4 to 1 from time to time.
If i make a backup to the harddrive all modules are saved. So this only occur when using USB
the workaround for this problem is to connect to the controller with robotstudio and make a small change in the missing module/modules and then save the module via robotstudio.
when this is done the missing modules will be copied when i make a backup to USB stick.
RobotWare 5.08
IRB 6600
Anyone who knows why this is happening?
