Hi guys I need help please,
when I drive manually in T1 from a point to another points robot take a path, But when I execute the program in AUT robot taking different path
please if somebody got an ideas
thank you
thank you
you need to provide more info, different path can be normal depending on program...
hi,
I attached a pic of the robot program, the P8233 and next point P822 drive in manual is ok doing what I want,when u run the program on Aut robot take different path on that point P822
thank you
hi thank you for your help,
I found out the problem was a position identifier,
