Hello
Gentlemen, this is a good solution Movement of mechanical stop A1 About two screws. And axis alignment A1 -220 +140 ?
Hello
...what?
i guess he is asking if it is ok to arrange A1 travel limits asymmetrically (range specified). if my interpretation is correct, that is not an issue (you can restrict travel range but not extend it). just make sure that soft limits match hard limits.
SkyeFire
Panic mode yes .I wanted to know if this is a permissible axis offset A1 about -220 Degrees.Due to the limitations of the cables behind the cover.
Ps. We have what celebrates panic mode has dumped you round number of posts 3000
i guess i type too much... or too often ..
time to cut back?
