Can someone help with an information regarding the amperes for outputs on CRMA58? I want to supply 2 lamps, 520mA each. Can I use two outputs or the 24V from the connector? I cannot find in the documentation. Is the connector protected by a fuse?
Thank you!
CRMA58 Amps
Casius -
January 24, 2017 at 2:18 PM -
What controller?
If i recall correctly, max amps for CRMA outputs should not exceed 0.2 amps per output (for R-30iB controller).
The 0.2 amps per output is right, but you should be able to draw more from the +24v pin. I have run two 400ma lights off the EE 24v pin for extended periods with no issues. They will always be on unless you have a relay if you go this route.
There is a fuse, you should be able to find it in the controller manual. Then you'll know for sure.
Sent from my VS985 4G using Tapatalk
