TP reset button to D0 for fault reset.
  • dmbj
  • December 15, 2016 at 12:35 AM
  • dmbj
    14
    202
    dose anyone know of a way to map the TP reset button to any DO? or how to monitor that it has been pressed.
    sure it will fault reset the robot, but not send a signal to a plc to reset other faults, in this case an area scanner.
  • bidzej
    23
    592
    • December 15, 2016 at 8:38 AM
    Havent't found a way to do it yet, but it is possible to write some code in the PLC to reset all the components if there is a negative edge of the Fault UO.
    This could also work with the scanner if you use it with the DCS Speed Check (R-30iA/B). If the scanner's fault state is somehow connected with the robot's E-Stop or Fence, this won't work though, because the robot's fault state won't be released...
  • skalactik
    13
    111
    • December 15, 2016 at 6:47 PM
    Quote
    If you have access to Karel, you can monitor for the occurence of TPIN[153] wich is the Reset key on the TP.
  • cobenson
    10
    314
    • December 15, 2016 at 11:58 PM
    TPIN[153]? My document says TPIN[145]
  • skalactik
    13
    111
    • December 16, 2016 at 10:22 AM
    I took the document from the Karel reference manual in Roboguide and it says that TPIN[153] is the Reset key. TPIN[145] should be the EDIT key. I double check with 2 other manual i got and they all agrees on that.
    Wich manual do you got and what version ?
  • dmbj
    14
    202
    • December 16, 2016 at 3:32 PM
    I like the DCS idea.
    Currently I was just using the scanner to drop my standard over ride down to 10% in the warning zone then external estop in critical zone.
    For now I just mapped jog button J8- to a DO for fault reset. monitoring system variable $DMSW_CFG.$KEYIMAGE=66
    Edited once, last by dmbj (December 19, 2016 at 11:46 PM).
