Base change issue
  • Marco
  • December 9, 2016 at 11:28 AM
  • Marco
    116
    Hello Everyone,
    I'm monitoring the actual base with the $ACT_BASE variable while running a program and I noticed that the base value is not changing to base 1 as supposed but the variable monitor shows 0 (I've set the continuous update of the monitor with the shift+enter). Here is my code, I do not see what is wrong. Can you help me with this?
    Very Best,
    Marco
    DEF BCT_A()
    GLOBAL INTERRUPT DECL 3 WHEN $STOPMESS==TRUE DO IR_STOPM ( )
    INTERRUPT ON 3
    BAS (#INITMOV,0)
    $LOAD=LOAD_DATA[1]
    $BASE=BASE_DATA[1]
    $TOOL=TOOL_DATA[2]
    HSD_LOGIC_SET=5
    $OUT[13] = FALSE
    HSD_SPEED_SET=0
    $TIMER[10] = -10000
    $TIMER_STOP[10] = FALSE
    WHILE NOT $TIMER_FLAG[10]
    ENDWHILE
    $VEL_AXIS[1]=15
    $VEL_AXIS[2]=15
    $VEL_AXIS[3]=15
    $VEL_AXIS[4]=15
    $VEL_AXIS[5]=15
    $VEL_AXIS[6]=15
    $ACC_AXIS[1]=70
    $ACC_AXIS[2]=70
    $ACC_AXIS[3]=70
    $ACC_AXIS[4]=70
    $ACC_AXIS[5]=70
    $ACC_AXIS[6]=70
    $VEL.CP=0.167
    $ACC.CP=2.3
    $VEL.ORI1=200
    $VEL.ORI2=200
    $ACC.ORI1=100
    $ACC.ORI2=100
    $advance=5
    $APO.CDIS=0.2
    PTP $POS_ACT
    $VEL.CP=0.167
    PTP {A1 46.934, A2 -35.843, A3 121.072, A4 0.105, A5 -85.313, A6 -0.016, E1 0, E2 0, E3 0, E4 0, E5 0, E6 0}
    LIN {X -0.188, Y 0.03, Z 100, A 133.204, B 0.086, C 179.933} C_DIS
    $VEL.CP=0.008
    LIN {X -0.038, Y 0.006, Z 20, A 133.204, B 0.086, C 179.933} C_DIS
    LIN {X 1499.959, Y 0.871, Z 22.828, A 152.602, B 0.104, C 179.965} C_DIS
    $VEL.CP=0.167
    LIN {X 1499.809, Y 0.895, Z 102.827, A 152.602, B 0.104, C 179.965} C_DIS
    HSD_SPEED_SET=0
    $TIMER[10] = -10000
    ENDWHILE
    PTP {A1 0.000, A2 -100.000, A3 120.000, A4 0.000, A5 -20.000, A6 0.000, E1 0, E2 0, E3 0, E4 0, E5 0, E6 0}
    END
    I'm running the program above through this program
    DEF alo_processing_cam_A( )
    ; --- DECLARATIONS ---
      DECL INT s,a
      s = 10
      a = 70
    ; --- INITIALIZATION
      $base = $world
      $tool = TOOL_DATA[1]
      $load = LOAD_DATA[1]
      $vel_axis[1]=s
      $vel_axis[2]=s
      $vel_axis[3]=s
      $vel_axis[4]=s
      $vel_axis[5]=s
      $vel_axis[6]=s
      $acc_axis[1]=a
      $acc_axis[2]=a
      $acc_axis[3]=a
      $acc_axis[4]=a
      $acc_axis[5]=a
      $acc_axis[6]=a
      ;$vel.cp = 2
      ;$vel.ori1 = 0.3
      ;$vel.ori2 = 0.3
      ;$acc.ori1 = 2
      ;$acc.ori2 = 2
      ;$advance = 2
      $OUT[6] = TRUE
      $OUT[7] = FALSE
    ; --- MAIN
      $OUT[9] = TRUE            ;com led on
      WAIT FOR HSD_SPEED_IN < 50
      PTP $POS_ACT
      ;LIN_REL {Z 100}
      PTP XHOME
      $OUT[9]=FALSE             ;com led off
    ; specify interrupt level and program name to call
    ; when PAUSE button is pressed... (wired to $IN[7])
      INTERRUPT DECL 10 WHEN $OUT[7] DO MoveAway()
    ;activate interrupt
      INTERRUPT ON 10
    ;enable fieldbus reference values for HSD
      $OUT[10] = TRUE
    ; pick tool
    ; PT0101()
    ; call CAM program to execute
    BCT_A()
    ; release tool
    ; RT0101()
    ; after milling program is finished, deactivate interrupt...
      INTERRUPT OFF 10
      HSD_LOGIC_SET = 5
      HSD_sPEED_SET = 0
      HSD_LOGIC_SET = 0
      $OUT[9] = TRUE
      PTP XHOME
      $OUT[9] = FALSE
      $OUT[6] = FALSE
      $OUT[10] = FALSE
    END
    DEF MoveAway()
      BRAKE ; need to pause current robot motion
      $OUT[10] = FALSE ;fieldbus reference values
      $VEL.CP = 0.005
      $ACC.CP = 0.01
      LIN_REL {Z 50} ; move robot up
      $TIMER[12] = -10000
      $TIMER_STOP[12] = FALSE
      WHILE NOT $TIMER_FLAG[12]
      ENDWHILE
      WAIT FOR NOT $OUT[7] ; wait until PAUSE is released
      $OUT[10] = TRUE ;fieldbus reference values
      $TIMER[13] = -10000
      $TIMER_STOP[13] = FALSE
      WHILE NOT $TIMER_FLAG[13]
      ENDWHILE
      LIN $POS_RET  ; return to last position to resume work
    END
    Kuka KR150-2 KRC2 ed05 V5.6.11<br />VFD TDE Macno<br />Spindle HSD ES915 with Automatic tool changer<br />Sprutcam 11
    Edited once, last by Marco (December 9, 2016 at 11:50 AM).
  • Fubini
    272
    1,873
    • December 9, 2016 at 11:44 AM
    The value of $ACT_BASE is only adapted if you use inlineforms! Actually the bas.src sets it whenever a base is set using the inline forms. So in expert programs you will have to set it yourself.
    Fubini
  • Marco
    116
    • December 9, 2016 at 11:54 AM
    You mean that the $ACT_BASE is not actually showing the base value changing during the run if there is change of the base along the program? I did some test and it seems that the value changes :wallbash:
    Edited once, last by Marco (December 9, 2016 at 12:02 PM).
  • Fubini
    272
    1,873
    • December 9, 2016 at 12:12 PM
    Yes it changes if and only if you use inline forms.
    Fubini
  • Marco
    116
    • December 9, 2016 at 12:17 PM
    OK then there is something strange going on here with the base:
    I have base 1 with Z=-36.787
    my digital model from which I get the CAM has the 0 at Z=-36.787
    I program the linear movement you have in the program above from point A to B with A at Z=20
    I run the program and stop it in A and the $POS_ACT shows Z=20
    I measure with the caliper the distance of the tool tip from the base and I get a measure of Z = 17.59
    $ACT_base shows value 0 rather then 1 (as programmed) during the run and after stop
    I leave the robot in the same position, I deselect the program, I set the tool (2) and the base (1) as from the program using the configure menu
    I go to the variable monitor and $pos_act shows Z= 17.59709 which matches with my measure done with the caliper
    So my conclusion is that the base loaded to run the program is not the right one. Am I right? Is my program syntax wrong?
  • Fubini
    272
    1,873
    • December 9, 2016 at 12:22 PM
    NO. Your program probably is fine. The value of $ACT_BASE is only changed when you use inline forms and yes also if you use the menu to choose the current base (I forgot about this case). The base is set correct.
    Fubini
    Edited once, last by Fubini (December 9, 2016 at 12:24 PM).
  • Spl
    5
    178
    • December 9, 2016 at 12:31 PM
    Try the linear move without the c_dis approximation. Also, instead of $base = ... you could use bas(#base,1) to set the base.
  • Marco
    116
    • December 9, 2016 at 12:55 PM
    Ok, now I used bas (#base,1) but still the same result, I stop the robot at point A and Z is 17.59 measured with the caliper while $pos_act says Z= 20. Then $pos_act says Z=17.59 if I check again the monitor after I deselect the program (the robot is still in the same position), set manually the tool and base with the same values i should have to run my program ... :wallbash:
    (btw the $act_base in the monitor is now changing from 0 to 1 while the program runs),
    Edited once, last by Marco (December 9, 2016 at 12:57 PM).
  • kr16_2
    378
    • December 9, 2016 at 3:05 PM
    $act_base is responsible for the little display icon that you are watching.
    Your program is working the way you want it.
    If you set $base = base_data[1] KRC is using base1 from now on.
    Your display is not changign because your are not setting it.
    Do this in your program:
    $base=base_data[4] ; sets the actual base
    $act_base=4 ; set value on user display
    If you are not sure what is going on continuously monitor $base variable to make sure it is not switching.
    Edited once, last by kr16_2 (December 9, 2016 at 3:07 PM).
  • Marco
    116
    • December 19, 2016 at 4:42 PM
    Quote from Spl
    I there,
    I solved the issue using bas (#base,basenumber) and I also had to use bas (#tool,toolnumber). I don't know why it works fine in this way and not with the other syntax $BASE=BASE_DATA[1] and $TOOL=TOOL_DATA[2].
    Does BAS work also for BAS (#load,loadnumber)?
    Anyway, it works. Thanks for your help!
    Best,
    Marco
  • SkyeFire
    1,044
    9,391
    • December 19, 2016 at 11:15 PM
    • #11
    Examining BAS.SRC will show you all the options it accepts. Usually, the #TOOL option (which is called as a normal extension of #FRAMES, which is normally called as an extension of #PARAMS) sets the $TOOL, $ACT_TOOL, and $LOAD values.
