Hi
I have an external axis setted to work synchronus with robot axis.
7-th axis is a rotary turntable used for workpiece milling.
I wish to know how could I increase the speed of this table?
From milling program I have a speed $VEL.CP=0.25 which means a feed rate of 15 m/min and normally in a linear milling motion robot moves pretty fast at this value, while I use 4 axis milling when tool stay almost fixed and workpiece rotates, the speed is not as fast as in linear motion.
Motor speed is 3750 rpm and gear ratio is 235:1 and that means I should have a maximum speed for table of 16 rpm.
But when run the program I merely have 2-3 rpm
How can I get 16 rpm while running a program in synchronus mode?
I used also variable $VEL_EXTAX[1]=100 (meaning 100%) but still not reach maximum rotating speed.
BAS(#VEL_PTP, 10)
BAS(#ACC_PTP, 10)
PTP $POS_ACT
$APO.CDIS=0.1
$APO.CORI=1
$APO.CVEL=100
$APO.CPTP=50
BAS(#VEL_PTP, 75)
$IPO_MODE=#BASE
$BASE=BASE_DATA[17]
$TOOL=TOOL_DATA[1]
$VEL.CP=0.25
$VEL_EXTAX[1]=100
EX_BASE(17,2)
$VEL.CP=0.083
LIN {X 625.67,Y 9.06, Z 359.55, A 92.01, B 0, C 0, E1 -136.4} C_VEL
LIN {X 500,Y 0, Z 359.55, A 92.01, B 0, C 0, E1 -137.84} C_VEL
LIN {X 500,Y 0, Z 250, A 92.01, B 0, C 0, E1 -137.84} C_VEL
$VEL.CP=0.25
LIN {X 500,Y -7.07, Z 249.9, A 92.01, B -1.62, C -0.06, E1 -139.46} C_VEL
LIN {X 500,Y -15.86, Z 249.5, A 92.01, B -3.63, C -0.13, E1 -141.48} C_VEL
Thank you
