I am currently learning this stuff on a LR mate small robot. The software I loaded is V3.2 Handling Pro. I have been trying to set up the DCS diagonal inside 1 zone. It errors out no matter what I try. Error code is 1, G1, M0. Wondering if anyone has any ideas.
DCS Cartesian Position Check
Mike T -
November 8, 2016 at 4:33 PM -
I assume you mean V8.2. V3.2 is really old.
Did you check the 3D view of your zones? You might have the floor of your zone intersecting the robot model.
Sad to say, it's the old 3.2 version. I did however check the 3D view, but I was only looking to see if the TCP was outside when it was faulting out. It was inside and looked ok. Thanks for the scoop, I'll check out the floor/robot model deal tonight.
I think DCS position check started about rev 7.2.
however
remember the safe side is not safe for the robot to go into. it is safe for a human to be there. so almost always set up your safe zones as diagonal out, not in.
I think DCS position check started about rev 7.2.however
Diagonal (safe-side In), or DI, is indeed intended as a space for the robot to be inside of.
What is the size of the zone? From what UserFrame is it referenced?
Diagonal-In is never used to indicate a place where a person is safe to be inside of.
Personnel safety at an Operator Load/Unload Station, in the context of a DCS Cartesian zone, is always a keep-out zone, or a Diagonal-Out with a disabling input to make it conditional (from the light curtain.) -
The V3.2 he mentioned im pretty sure is related to what version of DCS he has, and not the robot's core software version. I looked through some backups of previous robots we've worked on and couldn't find a robot with V3.2, but did find one with V3.1 and it's core software was V8.1, so I wouldn't think V3.2 is a very old version of DCS.
Yep, I messed that up. It is DCS 3.2 and Handling Pro 8.2. The UFRAME is 0. Point #1 is recorded at X=613.4, Y=-265.2, Z=206.1 , and Point #2 is recorded at X=169.2, Y=237.8, Z=-286.2. I tried to change the UFRAME to 1, but it would not let me. I have 3 UFRAMES entered in.(0,1,2)
What model do you have specified to keep inside the zone? Did you define a user model or are you using the robot model? Your zone is likely being violated by the robot model as Nation stated earlier.
Sent from my VS985 4G using Tapatalk
Yes I agree. If the robot body model (-1) is targeted, the zone is too small for the robot to stay inside of. The X values alone show that. This could explain being faulted "no matter what."
Box is too small for a DI [Diagonanal (safe side In)] if the default robot model is targeted.
