Hello all,
KRC4, KSS 8.3.xxx
I am working between several different modules and have a set of common points in between them. I am using the $CONFIG.DAT global user declarations to share these common points. Two questions regarding this method:
1) Do I have to manually enter the X,Y,Z,A,B,C values for an E6POS variable?
2) Which base system will these points use when I call a PTP motion for them?
Thanks!
