Very I need help to find the software for the robot IRB2400 m94a
otiko -
October 10, 2016 at 1:46 PM -
Do you have backup?
no, I need to show their work to the buyer, but the software is not present, you need ten key disc and floppy
You can't found original discs if you haven't backup or key file but you can ask your local ABB.
we bought a robot without software, changed batteries, now need to install the software but don't have the installation floppies, wrote to the company ABB, but got no answer, I am sure that there are enterprises such old robots, and I just copy the contents of ten disks, we can discuss the options for monetary compensation. I hope for your help. I have tried to install the software with irb2400 98a. but once the first floppy key disk, not what is changing on the screen. who can explain this?what is the difference m98a from m94a
if you haven't backup or key disk you are on hard way. Because key disk option has a lot of difference and probably you can't work with another key disk. You must be found similar controller.
... you can ask your local ABB.ABB will probably be able to help... for a fee.
I use 1-800-435-7365 (your access number may be different)
